Hi everyone,
I have a DDJ-SX2 and I try to work with timecode. I can't find the solution and I had tried so many audio config...
Macbook Pro Yosemite (last version)
Virtualdj 8 (last version)
Thanks for help!
Thanks for help!
geposted Wed 29 Apr 15 @ 12:27 am
By default, the input on the ddj-sx2 are not enabled because you have to buy the DVS upgrade pack for serato to enable the inputs on the sound card.
On a windows machine you can edit the registry to enable the DVS plugin , but i don't know how to do it on a mac...sorry
geposted Wed 29 Apr 15 @ 1:24 am
I have already the DVS pack for Serato...
geposted Wed 29 Apr 15 @ 1:27 am
there should be a com.seratodj.plist file in Users/YourUsername/Library/preferences FOlder. Use a Plist Editor and change a setting called dvs_enable or something like that to 1 (0 is default)
This will probably change the audio inputs/outputs routing and will be able to use the Inputs of the sound card in VirtualDJ 's Audio Setup.
This may help you as well.. http://www.virtualdj.com/wiki/MAC.%20Reveal%20hidden%20Library%20folder.html (to reveal the /Users/Library folder , hidden by default) ;)
geposted Wed 29 Apr 15 @ 3:32 am
Thanks djdad!
Timecode now working with DDJ-SX2 and VDJ8 using MAC.
You have to install the last firmware (1.05) for the SX2.
You have to install the last version of SeratoDJ.
Install DVS extension pack for SeratoDJ. (99$ USD).
ALWAYS open than close SeratoDJ before opening VDJ8. Don't miss this step... You won't be able to have DDJ-SX2 2IN2OUT in the menu.
For any question, do not hesitate to contact me :)
geposted Wed 29 Apr 15 @ 4:05 am
I am at os 10.6.8
How do I make VDJ 7 recognize my ddj-sx2 ?
geposted Sat 02 May 15 @ 9:18 pm
Ticoindamix wrote :
I am at os 10.6.8
Hi! VDJ 7 don't support DDJ-SX2 with PC or Mac. Sorry...
geposted Wed 06 May 15 @ 7:59 pm
Ticoindamix wrote :
I am at os 10.6.8
Thank you! I went with Serato. Also, tried using VDJ8 with the sx2 and although it works, some functions do not work the same. I'm sure there has to be a map already made, or whenever I can get to it, I'll do it myself.
geposted Sun 31 May 15 @ 10:35 am
Ticoindamix wrote :
I am at os 10.6.8
Hi Ticoindamix,
I use the skin for DDJ-SZ... Work great!
geposted Sun 31 May 15 @ 10:46 am
