Im told that there is a VDJ8 skin for the DDJ-SX2 but can't locate it. The one that I have is for VDJ7. Ive searched the skins section looking for it with no luck. Any suggestions on where to locate one. Thanks
geposted Fri 08 May 15 @ 2:04 pm
The Pioneer DDJ-SB 8Skin or PADS - Pioneer DDJ-SX/Z is out until some one make that skin.if you need it ASAP Djdad made Skin Builder,I have build a skin and use it on a event, once
geposted Sun 10 May 15 @ 10:55 am
There is no skin for DDJ-SX2 available, but the DDJ-SX or the DDJ-SZ should do the job
https://virtualdj.com/plugins/?category=skins&search=PADS
geposted Sun 10 May 15 @ 4:32 pm
Since the main reason you would want a skin made for SX2 is the pads mode (so that you can see on screen what the pads do) I would suggest you to use the SZ skin, since both SX2 and SZ offer the same mapping for them.
geposted Mon 11 May 15 @ 1:15 am
Thanks for the info. I am currently using the DDJ-SX VDJ7 skin and someone was telling me it could cause me problems. so far so good.
geposted Wed 13 May 15 @ 10:55 pm
Hi
geposted Wed 29 Nov 17 @ 7:46 am
hello
geposted Wed 29 Nov 17 @ 10:23 am
