In VJ7 there was an effect called flanged loop out which reduced the volume with every loop it made untill fade out.
When I use the same effect in VJ8 the volume doesn't reduce so after a couple of loops it stops abrupt.
Because I don't have a Pro account for VJ8, i'm not able to download the loopout effect on the website.
I don't have any experience with mapping but Is there a way to script an effect that looks like the flanged loop out effect including the volume fade out with every loop?
geposted Thu 21 May 15 @ 4:03 am
Use the V8 loop out effect (it fades) and apply a flanger to the output.
geposted Thu 21 May 15 @ 12:28 pm
I don't have the loop out effect because I haven't got a pro account.
geposted Fri 22 May 15 @ 2:38 am
Then use a repeat_start_instant script to drop the volume FX level.
geposted Fri 22 May 15 @ 11:33 am
