Is it possible to have different sorting to each folder?
In some folders I would like to sort on BPM, and some filter folders I would like to sort on Artist.
geposted Thu 21 May 15 @ 12:41 pm
Two ways I can think of,
a custom button to go to your filter folder and set the sort order.
get_browsed_folder & param_equal "Filter Folder" ? goto_last_folder & browser_sort "Bpm" : browser_gotofolder "Filter Folder path" & browser_sort "Artist"
You'll have to flesh it out but that's the idea.
The other is a repeat_start script but I don't like constant constant scripts, I'm not sure if it will flipflop the order ascending/descending, if it does you just need to throw a global ($) variable as a flag somewhere in the script
var_equal "$ArtistFlag" 0 ? browser_sort "Artist" & toggle "$ArtistFlag" & set "$BpmFlag" 0 : nothing
repeat_start "brwsrSort" 500ms & get_browsed_folder & param_equal "Filter Folder" ? browser_sort "Artist" : browser_sort "Bpm"
again you may have to flesh it out for multiple filter folders.
geposted Thu 21 May 15 @ 1:12 pm
Maybe filter folders should accept script.... maybe.
geposted Thu 21 May 15 @ 1:30 pm
There is a VDJ addon called My Library which will split all your songs into around 20 bpm bands, it also does much more, including alphabetical Artist listings.
http://www.virtualdj.com/plugins/index.html?category=other
It's a good piece of work by the dj-in-norway.
geposted Thu 21 May 15 @ 2:18 pm
I would prefer not to having a custom button or script to do the trick in this case. I have ran out of custom buttons.. (Thanks Loco for your scripts)
Ron, I may check out this add-on ! Thanks! 👍
geposted Fri 22 May 15 @ 1:25 am
