Forum: Old versions
Topic: Mac OS X 10.10.3 Problems
pelos5PRO InfinityMember since 2006
I installed Virtual DJ 7 pro on a Mac running 10.10.3 OS X Yosemite. But my computer does not recognize DJ Console Hercules RMX. What should I do?
geposted Mon 25 May 15 @ 10:54 pm
Try V8 or at least try V7.4.4
geposted Mon 25 May 15 @ 11:02 pm
DJ PhatsoPRO InfinityHercules Support TeamMember since 2005
geposted Tue 26 May 15 @ 8:15 am
I have MAC pro 10.10.3 retina 15 inch mid 2015 and, I ben having problems to install my Hercules Dj console Rmx .
geposted Tue 30 Jun 15 @ 4:47 pm
geposted Thu 02 Jul 15 @ 6:28 am
I use denon mc6000!!!!
geposted Thu 02 Jul 15 @ 8:25 am
Hi, I am having the same problem. (OS Yosemite 10.10.4)
I followed the instructions from hercules website. (download the new set of drivers, connect the device and restart). When I connect the controller, the lights start blinking and stay there indefinitely. I open the VDJ7 and the software did not interact.
I thought that updating the firmware is the problem and I found some instructions from hercules. Unfortunately, it does not work. I open the Manual update and when I press the MIC On/Off key before connecting the USB cable, the controller continues blinking.
http://ts.hercules.com/faqs/eng/her_eng_00385.pdf
I check the other references mentioned above and the controller is not listed in any references. I just got a new mac, probably I am missing something but I do not think so.
Your help will be highly appreciated.
geposted Sat 25 Jul 15 @ 4:46 pm
