i have been playing around with my nv fixed a problem i had with a nice firmware update :)
if anyone knows how to do this it would be great . also is there a filter roll ?
geposted Fri 29 May 15 @ 7:34 am
The Curve for the Volume faders can be adjusted with the setting FaderCurve (in the Advanced Options). You can set it to 0.0, 0.5 or 1.0
What exactly do you mean by "Break"
geposted Fri 29 May 15 @ 8:35 am
i want it to stop like a sl1200 turntable with out putting a fx on by just pressing stop
like i can with serato
geposted Fri 29 May 15 @ 7:03 pm
ok i found it rampstoptime even tighten the scratch time
geposted Fri 29 May 15 @ 7:10 pm
thanks for your help btw
geposted Fri 29 May 15 @ 7:22 pm
Check out Slipbreak8 FX if you want 12's style of braking in a slipped style.
geposted Sat 30 May 15 @ 10:31 am
