Using Virtual DJ 8 and a laptop that's had all the correct tweaks for playing music. I have no problem with the software whatsoever when I'm not using the controller. No latency, perfect mixes, grids line up perfectly. Here's where I run into a latency problem and it has happened on all 3 laptops I've used over four years. My auto mixes are off my a few milliseconds. I have to + one side every time. I could mix manually, but I like to record my mixes and if I use the controller, I run into the problem. Has this happened to anyone and what is the adjustment I can make? I'm afraid if I adjust for the controller, then when NOT using the controller, the auto mixes won't still be perfect.
I look forward to some advice. Thank you.
geposted Sun 31 May 15 @ 3:57 pm
I figured it out. I just realized that when I've been using another soundcard for another software at the same time.
geposted Sun 31 May 15 @ 7:24 pm
