Topic: What Is The OEM And LE
The Title Is The Question
What Do OEM And LE Means
Thx All
geposted Mon 01 Jun 15 @ 1:08 am
OME, Other Makers Equipment
LE Limited Edition
geposted Mon 01 Jun 15 @ 1:12 am
thx loco for responding so fast
but the reason i asked because its showing beside my login name ( pro OEM )
and beside your name for example ( Pro infinity )
and In My Virtual Dj 8 License Section It Shows Pro Infinity
So Why It Shows Different In Both
geposted Mon 01 Jun 15 @ 1:36 am
jakovskiPRO InfinityStaffMember since 2006
It just means that you get your Infinity lizense from Pioneer together with your DDJ-SZ and not from the Atomix Webshop. It's more kind of information for staff and support.
Greets, Heiko
geposted Mon 01 Jun 15 @ 1:45 am
thx Heiko
Thx Loco
Your GR8 And Helpful
geposted Mon 01 Jun 15 @ 2:51 am
RobRensPRO (OEM)Member since 2018
if i would buy a reloop touch, i get pro infinity oem with that, will my vdj version also support other decks or do i have to buy a pro version seperately ?? will it also work just on the laptop, without controller ?
geposted Tue 10 Jul 18 @ 10:42 am
First of all please refrain from re-opening very old threads (over 1 year).
The license that comes with the Reloop Touch is a full Pro license, so it will work with other controllers and with no controller...
...BUT it is linked to the Touch, meaning that it will require you to connect the Touch sometimes.
geposted Tue 10 Jul 18 @ 11:08 am
Does the Numark PartyMix controller come with an OEM license? I know I have a LE license, checking if I was supposed to receive an OEM license as well from the retailer.
geposted Fri 01 May 20 @ 2:08 pm
No, it's LE only.
Pro OEM is for expensive Pioneer units.
geposted Fri 01 May 20 @ 3:38 pm
Ok cool, I am just checking with some of my features being switched turned off. I am not planning of doing any gigs. I just want to play around with it at home for entertaining myself and guests.
geposted Fri 01 May 20 @ 4:26 pm
Yeah, some LE versions are so crippled they are virtually unusable. It's a shame but that's how it rolls.
geposted Fri 01 May 20 @ 4:28 pm
You can buy a Partymix license for $49 if you're only using it at home.
geposted Fri 01 May 20 @ 4:42 pm
