I don't intend to try Windows 10 til after the wedding season is over (November for me), or maybe after Christmas even.
Just wondering, has anyone installed it on a boot camped Mac?
geposted Wed 12 Aug 15 @ 5:38 am
lovemountain wrote :
I am running Windows 10 on an HP Envy. When I start Virtual DJ 8, I get a mostly black screen with a bit of the software visible in the upper left hand corner. If I adjust the screen resolution up or down, I can see all of the Virtual DJ screen. This is not a permanent fix for if I close Virtual DJ, when I reopen, I have the same problem. Any thoughts or suggestions would be greatly appreciated
You need to install the drivers for your video card again. Suggested to look into the manufacture's page and install the latest available ones.
geposted Wed 12 Aug 15 @ 1:51 pm
That worked great. Thank you so much
geposted Wed 12 Aug 15 @ 5:20 pm
bobhoffman wrote :
anyone one run windows 10 with vdj 7 ?
wondering how that went.
I have bad issues with 8 still, so not on our club computer...we still use the stable 7 until 8 perks up for us.
I had Windows 10 with 7 and 8 and they both had problems. I reverted back to Windows 7 and all my problems went away.
geposted Thu 10 Sep 15 @ 7:40 pm
I have installed windows 10 and virtual DJ 8 on my Dell Notebook. I have no problems. All features are corect.
geposted Sat 12 Sep 15 @ 8:49 am
Some Latency issues over here.
I have done a clean install of Windows 10 Enterprise 64-bit since release from my MSDN account, but I have noticed that during play if I would go into a folder on the machine and scroll in it, it starts to hick the music. Under the same system with Windows 7 Enterprise 64-bit never had these issues.
VDJ 8.0 build 2441.1067
Hercules Rmx using the latest drivers 5 HDJS. 2015
HP ProBook 6460b
12 GB
4TB Porsche Desktop Drive
I have increased the ASIO Buffer on the Hercules to the max, but still.
HP ProBook 6460b
12 GB
geposted Mon 21 Sep 15 @ 7:16 pm
Okay, I have solved the latency issue.
I am really getting old, forgot that I had to redo all the special configs as I had done a clean install on the machine. When I was still running Windows 7 I had done the following steps to Optimize the folders which solves the he load-delay.
In the properties window of the Music Folder, Click the Customize tab. Under the “Optimize this folder for: drop-down menu, Select General Items.
Now when scrolling into folders, the hicks are gone.
geposted Mon 21 Sep 15 @ 7:59 pm
I am just wondering if I upgrade my acer laptop to windows 10 wood virtual dj 8 crash or not work properly ? Please Help
geposted Mon 30 Nov 15 @ 3:33 am
Read the whole of this thread.
geposted Mon 30 Nov 15 @ 8:46 am
What, if I read the whole thread, I might........never mind.
geposted Mon 30 Nov 15 @ 6:13 pm
If use vdj8 on windows 10 would it work properly ?
geposted Tue 01 Dec 15 @ 3:39 am
What makes you think it won't? Why not just try it?
geposted Tue 01 Dec 15 @ 9:48 pm
I too am having an issue where my computer wishes to up grade to windows 10 from 7 that I'm using now, my issue is will VDJ 8 work with 10? also will 7 still work with 10? and will my Denon 6000 still work with the Windows 10? It's working fine now with 7 and 8.
thanks for your assistance in this,
Mike Bendavid
Mike Bendavid
geposted Sat 05 Dec 15 @ 12:39 am
Mike, have you read this thread?
geposted Sat 05 Dec 15 @ 3:22 am
Win10 proved very buggy and troublesome at first so I decided to bite the bullet following numerous computer specialist articles in the general press on the matter.
I backed up my music folders and took a copy of the database before doing an upgrade - I say upgrade, but now that the new Windows 10 (1511, 10586) version is out it allows you to install using your genuine Windows 7/8/8.1 product key from a clean install. This makes Windows 10 far less likely to crap out on you as the install is clean and unfettered by remnants and stuff from previous versions.
Once done, install and necessary drivers for controllers (eg. in my case the Denon ASIO drivers for my HC-4500), allow Windows to fully update itself any further to get all the "improvements" out of the way, and finally reload VirtualDJ and then copy your music archive and database back to exactly the same places it all came from.
This worked beautifully for me, reduced my cold boot time to less than 12 seconds including VDJ in the startup programs. No crashes, stuttering, USB "unknown device" issues or anything anymore, just a really nice fast VDJ laptop which is a pleasure to use again.
geposted Sat 05 Dec 15 @ 3:59 pm
Well I upgraded my acer laptop to windows 10 and it seems that vdj8 is working great Thanks for everyones support in this matter Have fun and enjoy
geposted Sat 05 Dec 15 @ 4:32 pm
hi guys
happy new yr
windows 10 seems to be a no no for me at the moment I am getting crashes on my American audio vms 4.1
it was running fine until vdj updated
can anyone tell me if there is a bug proof set up for windows 10 ?
crash free set up ?
a guide like viper done for windows 7 just for windows 10 ?
my system seems to crash every 2 hrs now its really doin my head in now
help appreciated :)
happy new yr
crash free set up ?
help appreciated :)
geposted Sat 02 Jan 16 @ 5:05 pm
markb7611 wrote :
hi guys
happy new yr
crash free set up ?
help appreciated :)
happy new yr
crash free set up ?
help appreciated :)
What are your system specs? (Processor, Memory, etc.)
It most likely has to do with your memory.
geposted Sat 02 Jan 16 @ 8:13 pm
Hi DJ folks, I'm getting an issue with VDJ7 PRO on my Acer 481PT (i5 / 6 GB RAM) running Windows 10. I never encountered issues with WIN 8 and after the WIN 10 upgrade things were running smoothly until the last big Windows upgrade a couple of weeks ago. Since then, VDJ7 works intermittently when I try to use the software only at home. However, when I connect to the pub's Numark controller every Thursday the program loads perfectly and I have no issues throughout the gig. However, when I disconnect and try the VDJ software at home, sometimes it loads and works fine and then sometimes it doesn't. So far I've tried uninstalling and re-installing and I've upgraded my Realtek Audio drivers but the software still works basically when it wants. I downloaded the VDJ 8 trail version from the site and this loads and works fine so it seems to be a conflict with VDJ7 and WIN10. Any ideas as to how to resolve this problem? One other quick question......during all these tests and trials, I've lost my VDJ data in the form of cue points, BPM's etc. twice. How can I back up my database to save this information? Do I save a particular file to a flash drive and just copy and paste it back and forth?
geposted Sun 03 Jan 16 @ 4:45 pm
Part of the problem with consumer versions of Windows 10 is that the user has no control over the updates, and as we know MS updates are notorious for screwing things up. That's one of the reasons I wouldn't touch it with a bargepole.
I can't help but thanks for the feedback.
geposted Sun 03 Jan 16 @ 4:55 pm
