I had that as well and can't remember how I fixed it ........
geposted Tue 25 Aug 15 @ 2:28 pm
really would like some help with this issue as its a paid app i am unable to use
geposted Tue 25 Aug 15 @ 2:33 pm
88pauley wrote :
purchased the app on my old android device and when i installed the Apk on my new device it says NO VALID LICENSE FOUND Any help with this issue would be appreciated
When you say you 'installed the apk' what do you mean? You installed it on your new device from the play store? Or you copied the apk from your old device to your new one?
geposted Tue 25 Aug 15 @ 2:34 pm
I seem to remember I copied it across with Titanium Backup and it wouldn't work. Once I cleared the cache & data then reinstalled it all was working again.
geposted Tue 25 Aug 15 @ 3:04 pm
Yes I extracted the Apk_File from my old device from my PC as the screen was broke and i could not see it i then installed it on my new device and it says NO VALID LICENSE FOUND
geposted Tue 25 Aug 15 @ 5:07 pm
Go to application manager, clear cache, clear data then uninstall it.
Then go to play store and reinstall. that should sort it.
geposted Tue 25 Aug 15 @ 5:19 pm
I already tried this it didn't solve my problem
geposted Tue 25 Aug 15 @ 5:35 pm
Have you rebooted the device?
geposted Tue 25 Aug 15 @ 5:39 pm
Yes multiple times
geposted Tue 25 Aug 15 @ 5:59 pm
Why didn't you just install it from the play store like normal? Surely that's easier than extracting the APK, copying it over and reinstalling it? Did something prevent you from doing that?
The software is licensed against your google account and the actual license status is determined and returned by Google themselves, so please make sure you have the correct google account on your device.
geposted Tue 25 Aug 15 @ 8:13 pm
SBDJ wrote :
As I've said before, you can already use USB.
Is this the same way the Serato Remote works??
geposted Wed 26 Aug 15 @ 1:54 am
Thanks and i fixed my problem had to factory reset my device and sign in with my google account i purchased the application with I have 2 different emails work/personal had not realized i purchased the app on my work email thanks for all the effort and help guys // for future reference i have recently just realized/(Learned) that i can have multiple accounts on the same device but the one that you use 1st during initial device setup becomes locked to the device and can only be removed with a factory/master reset
geposted Wed 26 Aug 15 @ 2:39 pm
I've no idea, I've never used it. I also don't own any iOS devices myself at present.
For our remote, just enable USB tethering and you should be good to go.
geposted Wed 26 Aug 15 @ 6:08 pm
Yeah that's not the same thing then, there's is actually midi over USB where ours is not.
Anyway we can get it to work over USB without the need to tether??
geposted Wed 26 Aug 15 @ 7:51 pm
That defeats the purpose of having a remote
geposted Wed 26 Aug 15 @ 8:03 pm
Love the remote. I use a HTC One M8 and it's flawless. I tried Tablet skin, but the sliders at the bottom were missing. I could not find a default value in VDJ8 or the remote. There is no default skin to fall back to, but instead of uninstalling/Re-installing the app, just clear your App Data, and Cache from your Android device and it sets the default skin back on the device.
Click the + sing next to the vinyl and you can use your mixer and volume control.
geposted Wed 26 Aug 15 @ 8:35 pm
Not really, I don't always have WiFi and I'm not gonna carry a router around as for it being called a "remote" that's just a fancy way of saying "wireless controller" which that's all it is to me, I don't use it for the library, I use it as a SP1 so yeah I'd like to see this also connect via USB.
geposted Wed 26 Aug 15 @ 8:59 pm
There is no nice way to do that for Android - you could do it using ADB but that requires the right drivers, developer and debugging mode on the Android device etc, it's a mess.
I couldn't say for iOS.
geposted Thu 27 Aug 15 @ 1:10 am
If I need any Viagra I'll let you know :)
Hi Scott,
Any news on an update to address the sidelist/automix scrolling issue?
Thanks - Keith
Hi Scott,
Thanks - Keith
geposted Wed 02 Sep 15 @ 9:38 am
The bug regarding the non-scrolling was reported on 19th June, which was nearly 11 weeks ago.
This is getting a bit ridiculous, considering it is a paid app it should be getting a bit more attention. The exe is getting a weekly bug fix but this is just getting ignored like the last version.
geposted Thu 03 Sep 15 @ 3:58 pm
