Forum: Old versions
Topic: NS6 VDJ8 cannot preview other deck
Hi Guys I don't seem to be able to preview the next track on the next deck through my headphones I can only hear the current side that is playing through the speakers.
geposted Sun 07 Jun 15 @ 1:25 pm
here is my setup at present
Tip for the future, screen shots are better if you,
Press Prt Sc button top right of keyboard usually, open M$paint, Ctrl+V, save and upload.
Let's see a picture of your master panel.
You will have to install (or re-install) the Numark ASIO drivers for the NS6
http://www.numark.com/product/ns6
Try both drivers but prefer the 2.9.64 one
Once installed, open VirtualDJ an click on the Numark NS6 button in order the pre-defined audio configuration to be created.
If still showing WASAPI, click on the drop down list of the sound cards and post a screenshot to see what options you have there.
Even though i would recommend to resolve the ASIO driver issue (by following the above), you still can use Wasapi and have proper pre-listening.
Please see here.. https://virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html
