Forum: Old versions
Topic: Headphones and speaker audio option?
Hey guys, I am confused about this option in the Audio setup, does it mean you can listen to both the laptop's internal speaker and your headphone out at the same time? If yes, that is not working, I am only getting audio from the headphone out when I choose that option, any ideas please?
geposted Mon 08 Jun 15 @ 3:48 pm
As stated on page 78 of the VDJ 8 User's Guide, it creates a master/headphones setup.
This is the standard DJ audio config. Your master output is what the audience hears, and the headphone output is for the DJ to cue (prelisten).
To do this, you need two separate independent stereo outputs. One for speakers, one for headphones.
A laptop will normally only have one, feeding the built in speakers. If you plug headphones into the laptop, this will cut off the internal speakers and the sound will be fed to the headphones. Completely normal for consumers, but no good for DJ use.
oops, pardon. nothing to see here.
Got it, thanks. Is that hercules soundcard better than the Numark DJ I/O?
I would say yes. Plus I think the Hercules is actually recommended by Atomix for use with VDJ.
