Forum: Old versions
Topic: Video effects on enabling a sound effect
Hi,
I am using an NS 7 II controller with VDJ8 on Mac OS X Yosemite. I have set the FX Mode to Multi FX Mode so that each FX knob has its own sound effect.
I would like to enable a video effect when I enable a sound effect from the controller. Any ideas on how to go about achieving this?
geposted Tue 09 Jun 15 @ 11:09 am
Hmm, can you provide an example ?
E.g. you want the Video Effect "Colorize" to get enabled when "Flanger" Audio Effect is enabled ??
geposted Tue 09 Jun 15 @ 4:07 pm
Exactly!! Spot on...
geposted Tue 09 Jun 15 @ 11:55 pm
it depends on how you activate the Effects.
E.g. this action assigned to a button should do what you want.
effect_active 'Flanger' ? effect_active 'Colorize' off & effect_active 'Flanger' off : effect_active 'Colorize' on & effect_active 'Flanger' on
geposted Wed 10 Jun 15 @ 2:26 am
Hi djdad,
Thanks for your prompt response.
I am using an NS7II controller and the actions are as shown below.
Where should fix that piece of code? Many thanks...
geposted Wed 10 Jun 15 @ 5:16 am
Help me to help you ;)
which button of the NS7II do you wish to work like this ?
please declare it by its Key name of the mapping or the name that has on the silkscreen on the unit
Is it only one specific Effect that you wish to enable a specific Video Effect (like the example above) ?
Do you wish this behavior to apply on all 3 Slots of the Multi FX mode ?
geposted Wed 10 Jun 15 @ 7:36 pm
I would like this behaviour on all 3 slots of the Multi FX mode. FX1, FX2 and FX3
When the effect is active, I would like the 'Spectral' video effect. Let me know if that makes sense?
Many thanks.
geposted Thu 11 Jun 15 @ 8:39 am
murayadavid wrote :
When the effect is active, ...
Any effect or some particular ?
and do you want the Video Effect to apply on the deck or the Master Video Output ?
geposted Thu 11 Jun 15 @ 5:47 pm
I would like the Spectral effect on the master video output.
Thanks
geposted Mon 15 Jun 15 @ 3:14 am
Djdad, any progress on this?
geposted Wed 08 Jul 15 @ 2:48 am
