Forum: VirtualDJ Skins
Topic: crossfader 'audio/video/linked' code gone wrong
Any ideas why this wont work? The graphics are all fine but the buttons dont function as 'only this one on'
I've spent aaages on this with no joy :-(
<group name="crossfader_sources" x="+100" y="+170">
<button x="+195" y="+361" action="skin_panel 'linked_cross' on">
<size width="49" height="28"/>
<off x="497" y="3500"/>
<over x="547" y="3500"/>
<on x="597" y="3500"/>
</button>
<button x="+140" y="+361" action="skin_panel 'audio_cross' on">
<on x="597" y="3470"/>
<over x="547" y="3470"/>
<off x="497" y="3470"/>
</button>
<button x="+251" y="+361" action="skin_panel 'video_cross' on">
<off x="497" y="3530"/>
<over x="547" y="3530"/>
<on x="597" y="3530"/>
</button>
<panel id="audio_cross" group="crossfader_sources" visible="yes">
<slider action="crossfader" rightclick="temporary" dblclick="crossfader 50%" orientation="horizontal">
<pos x="+131" y="+500"/>
<size width="179" height="41"/>
<selected x="784" y="3102"/>
<up x="784" y="3102"/>
<fader>
<size width="39" height="43"/>
<pos x="684" y="3100"/>
</fader>
</slider>
</panel>
<panel id="video_cross" group="crossfader_sources" visible="no">
<slider action="video_crossfader" rightclick="temporary" dblclick="video_crossfader 50%" orientation="horizontal">
<fader>
</fader>
</slider>
</panel>
<panel id="linked_cross" group="crossfader_sources" visible="no">
<slider action="video_crossfader_link" rightclick="temporary" dblclick="video_crossfader_link 50%" orientation="horizontal">
<fader>
</fader>
</slider>
</panel>
</group>
geposted Wed 10 Jun 15 @ 8:32 am
does the linked crossfader command only work on an existing video and audio cross? Maybe i'll try to put both in the same panel (linked), same co-ords..
#clutchingatstraws
Ha! all sorted. Easy to sort with your head not stuck up your own *** :D (it was a basic schoolboy error *ashamed)
video_crossfader_link is not a slider. It has to be a on/off button.
Assuming you need to provide a slider which it will control both Audio and Video crossfaders, your 3rd panel must have a slider with action="croossfader & video_crossfader"
If you want to offer more automations, you will probably need to enable LINK when you select the 3rd panel and possibly turn off when the other 2 panels get visible.
Note also that AUTO and LINK cannot be enabled at the same time
I realised my error trying to code 'link' as if it was a third type of crossover.... ooops!
