I'm trying to modify a skin and change what is displayed on Hot Cue 1 button. I've got the basics sorted but I want it to show a beat countdown to Hot Cue 2, which I got working but it continues to count after Hot Cue 2 has passed. I'd rather it stop or remove counter. I've tried this:
<text size="15" format="`%Btocue2 > 0 ? 1\n%Btocue2 : 1`"/>
In theory that should work if you can query %Btocue2. All I get is a blank button. Any ideas and thanks in advance....
geposted Thu 11 Jun 15 @ 7:57 am
Looks like this is the solution: https://virtualdj.com/forums/200911/VirtualDJ_Skins/played_cue_value_visibilities_.html
geposted Thu 11 Jun 15 @ 8:13 am
Actually, I'm having a mare.... Trying to modify the appearance of the Hot Cue button (show beats to next cue) depending on whether the next Hot Cue Position has been reached. I know it's the query that isn't working:
<button class="sidebutton" x="+6" y="+37" action="hot_cue 1" rightclick="holding 2000ms ? delete_cue 1 : goto_cue 1"><text size="15" action="var_greater '%Btocue2' 0 ? get_text '1' : get_text '1\n%Btocue2'"/></button>
Can any body save my sanity?
geposted Sun 14 Jun 15 @ 10:02 am
Try something like this:
</button>
<textzone visibility="get_text '%PBfromcue1' & param_cast 'integer' & param_bigger 0 ? true : false">
<text size="15" format="'%Btcue2'"/>
</textzone>
So the text zone will only show up if %Pfromcue1 >0
Hope this helps ;o)
</button>
</textzone>
Hope this helps ;o)
geposted Sun 14 Jun 15 @ 11:54 am
Thanks for the advice.... Just to make 100% sure I understand the syntax.... The button element is closed before the textzone element is created and therefore the whole line would look like this:
<button class="sidebutton" x="+6" y="+37" action="hot_cue 1" rightclick="holding 2000ms ? delete_cue 1 : goto_cue 1"></button><textzone visibility="get_text '%PBfromcue1' & param_cast 'integer' & param_bigger 0 ? true : false"><text size="15" format="'%Btcue2'"/></textzone>
geposted Sun 14 Jun 15 @ 12:21 pm
I prefer two elements. If you will place it in one element:
<button class="sidebutton" action="hot_cue 1" rightclick="holding 2000ms ? delete_cue 1 : goto_cue 1">
<pos x="+6" y="+37" />
<text visibility="get_text '%PBfromcue1' & param_cast 'integer' & param_bigger 0 ? true : false" size="15" format="'%Btcue2'"/>
</button>
should work.
skin-wiki:
https://virtualdj.com/wiki/SkinSDK8.html
</button>
should work.
skin-wiki:
geposted Sun 14 Jun 15 @ 1:56 pm
Thanks...
Must have read the wiki like 20 times and slowly starting to get to grips with it :-)
geposted Sun 14 Jun 15 @ 2:10 pm
What skin do you want to modify?
geposted Sun 14 Jun 15 @ 2:28 pm
I'm playing around with V8 by Fruit... It has almost everything I want, but just want to tweak a couple of things.
geposted Sun 14 Jun 15 @ 2:59 pm
One thing I'm struggling to get my head around is that if the <textzone> element is not contained withing the button element, how does VDJ knows which button to print the text on? Is it just the last defined element?
geposted Mon 15 Jun 15 @ 2:48 am
So I tried this today and it didn't work. I just got the normal display all of the time i.e. beat counter. ??
geposted Mon 15 Jun 15 @ 8:18 am
It doesn't.
A textzone prints a text where you tell it to print by it's <pos /> coordintes.
You can print on top of ANY element you may think off since Version 8 just layers the graphics one above each other.
In other words a <textzone /> doesn't need to be contained in anything.
geposted Mon 15 Jun 15 @ 8:47 am
Ah, what I thought. Thanks for the info.
geposted Mon 15 Jun 15 @ 9:48 am
