I appear to have downloaded to cache a song with 4 very nice hot que points !?.
SCRATCHES HEAD.
LOL that saves time !
SCRATCHES HEAD.
geposted Wed 17 Jun 15 @ 6:42 am
Some CU tracks do indeed have pre-assigned cue points.
geposted Wed 17 Jun 15 @ 6:45 am
It's not that some songs wont load, rather they load very slowly, and I move on to the next.
Mind you I'm using my phone hotspot to use up my data allowance since I start a new month next week.
I don't as yet know what works well, and what doesn't.
That slow to download song has 8 hot cue points !
By the way these are uk top 40 songs.
geposted Wed 17 Jun 15 @ 7:40 am
Which song is it - i'll compare here
geposted Wed 17 Jun 15 @ 8:23 am
"Where are U now" 8 hot cue version.
geposted Wed 17 Jun 15 @ 8:47 am
It's a pity we can't create sub-folders in the "Downloaded content" folder.
It could rapidly become unmanageable.
Hm maybe we can !
----->My Documents/VirtualDJ/cache and just manage things there...we'll see.
That does not work.
The first folder I would want to create would be "UK Top 40".
OK so you can create a new folder on your hdd, call it what you want, and move the relevant cached songs.
You may need to base things on the "Downloaded content" folder, and relocate every moved file to enable cache refreshment every month.
I just don't know.
Hm maybe we can !
That does not work.
I just don't know.
geposted Wed 17 Jun 15 @ 9:18 am
You can create filter folders that only pull from the path to the CU directory.
geposted Wed 17 Jun 15 @ 9:27 am
Can you give an example Blckjck ?
geposted Wed 17 Jun 15 @ 9:36 am
At the moment I have a nice new folder called UK Top 40 which lives in the cache folder. I have set this folder as a favourite, hence it is immediately available in the vdj explorer window.
It works, but I don't know if the cache will refresh.
geposted Wed 17 Jun 15 @ 9:42 am
I've got a usb cable running from my laptop to keep my phone charged, that might mean usb tethering is preferable if it keeps the phone charged?
There again it might be wise to keep it plugged into a proper charger?
I'm still using it as a hotspot at the moment, its been running all afternoon.
The phone battery charge level is100%.
geposted Wed 17 Jun 15 @ 9:52 am
@ bigron
if you make a virtual folder(that's the red ones) inside of another normal folder ie 2015 singles then you can drop your CU files(or at least a link) into them.
mine looks like this;
maybe there's a better way, I'd be interested to find out.
regards
ray
regards
ray
geposted Wed 17 Jun 15 @ 9:58 am
Nice one Ray, I think that is a great answer.
That was easy!
That was easy!
geposted Wed 17 Jun 15 @ 10:00 am
just want to add that Virtual folders are so useful, they've changed the way that I organise my music so much, and you can nest them!
btw. that's the first song "where are u now" that I've downloaded that has had hot cues already in it, that's amazing, so it's thanks to you for pointing that out.
geposted Wed 17 Jun 15 @ 10:26 am
