In the current build, you can't sort by Key. You come up with nothing. My backup laptop had an older build (I don't recall which and the search for Key was fine. I accepted the update so both laptops are current and now both have the problem.
geposted Mon 15 Jun 15 @ 12:51 am
Working here buddy but it has lead me to this.
geposted Mon 15 Jun 15 @ 5:17 am
I have Key checked. Try searching for a key, like 5B for me.
It worked fine until I upgraded the build. Key is the only one that comes up blank in a search.
geposted Mon 15 Jun 15 @ 8:10 am
Xb is a major key so pretty rare, although harmonic it isn't a searchable field from what I see, are you saying it was?
geposted Mon 15 Jun 15 @ 12:11 pm
It doesn't matter the key, pick any of them. They can't be searched. It's a bug.
Cap Capello and I narrowed it down to a build he has from March that works.
geposted Mon 15 Jun 15 @ 12:23 pm
Hi, I have the same problem after the last upgrade.
Search by harmonic does not work any more.
geposted Mon 15 Jun 15 @ 3:18 pm
Was Search by Harmonic ever working ? I have the feeling that its only the Search by "Key" that it was available and works fine here if Key is included in the Search Options.
geposted Mon 15 Jun 15 @ 3:20 pm
It used to work. You select Key as one of the search options and search for the number. I have a build that a friend gave me that dates back to March and the search worked fine at that point.
geposted Mon 15 Jun 15 @ 3:48 pm
Ok submitted to Dev Team. Makes sense to have both working. So either it will be fixed or Harmonic will be added in Search Options.
geposted Mon 15 Jun 15 @ 6:28 pm
I called Virtual today. No help what so ever. I have to wait until it gets fixed.
geposted Mon 15 Jun 15 @ 6:32 pm
I'm not sure that you didn't get help.
It has been reported to the developers to get looked at. Support would not be able to do much more then that. Was there something else that you need or expect?
geposted Mon 15 Jun 15 @ 11:36 pm
@djdad, do my pics show a bug?
<Bong> shows 6 results that are Gm.
<Bong Gm> only pulls 3 results.
geposted Tue 16 Jun 15 @ 1:13 am
This will be fixed in the next available build.
geposted Tue 16 Jun 15 @ 10:54 am
Thank you. For now I went back to a March build.
geposted Tue 16 Jun 15 @ 3:01 pm
Thank you for fixing it. Now I'm back to running a current build.
geposted Mon 22 Jun 15 @ 12:00 am
No problem :)
geposted Mon 22 Jun 15 @ 2:49 am
