I have had nothing but problems with Mac/VDJ 7/8. 7 is completely unusable, 8 has issues with Karaoke zip files.
If you have been able to get it working please tell us the tricks that you need to know to get it running solid!
Thank you in advance.
geposted Mon 15 Jun 15 @ 1:34 am
I'v played a few times just to see if it will work and had no problem with the system. At first it did not work using the USB ports, so i plug into the lightning bolt port and it work fine with no problems. Hope this help, good luck.....
geposted Mon 13 Jul 15 @ 10:57 pm
Trying out the new macbook pro tomorrow night for the first time. Seems fine in practice.
geposted Fri 17 Jul 15 @ 8:37 am
Run VDJ8 with Macbook Pro retina 2014 and external LaCie hardrive plugged into thunderbolt. Runs brilliantly, no glitches no hanging. My karaoke files are all mp4 though.....
geposted Sat 18 Jul 15 @ 5:02 am
I use CD+G ZIPs. No issues. Over 80k files as well. 2 shows week with karaoke.
MBP Late 2013. VDJ8.
I also mapped Dicers and some keyboard actions to add to karaoke list and edit singer info.
geposted Fri 24 Jul 15 @ 9:36 pm
