Hi, I always have to resize "Tag Editor window" to see all the tags (ex. genre is hidden on the left side).
Is there a way to force "Tag Editor window size" to a good size ?
Thanks
David
Thanks
David
geposted Wed 17 Jun 15 @ 11:02 pm
I also think that the size of resized windows should be remembered (stored in settings.xml?) because I have had similar issues when running VDJ 8 on small screens.
geposted Thu 18 Jun 15 @ 11:53 am
This problem occurs even in 1920x1080 resolution !
geposted Thu 18 Jun 15 @ 11:41 pm
The translation in french for 'first seen' seems a bit long, causing a lot of wasted space.
geposted Fri 19 Jun 15 @ 2:09 am
Thanks for the help Adion.
I reduce the text size in C:\Users\User\Documents\VirtualDJ\Languages\French.xml
VirtualDJ developpers should allow user to define window size anyway so we can keep a good translation.
geposted Fri 19 Jun 15 @ 6:26 pm
And what would be the line for text size ?
geposted Thu 16 Nov 17 @ 8:04 pm
