Hi folks, es betrifft mich zwar nicht mehr persönlich, aber ADJ hat mir nun nach langer Zeit doch noch die MIDI-Tabelle für den VMS2 zugesandt.
Falls Bedarf besteht...
VMS2 MIDI interface definition
NOTE: all MIDI messages use channel 1, Directions OUT and IN are relative to the MIDI station
Control number is in decimal format
All rotary VRs start at the minimum in the leftmost position and increase to the maximum when turned clockwise
For touch sliders, MIDI value depends on the finger position the last time the slider was touched.
Description Control type # I/O Object Values Shift Left Shift Right
CUE Left Note on 90H 12 C 0 OUT Button 00H = released, 7FH = pressed OFF N/A
PLAY > Left Note on 90H 13 C# 0 OUT Button 00H = released, 7FH = pressed OFF N/A
PAUSE || Left Note on 90H 14 D 0 OUT Button 00H = released, 7FH = pressed OFF N/A
PITCH BEND - Left Note on 90H 15 D# 0 OUT Button 00H = released, 7FH = pressed OFF N/A
PITCH BEND + Left Note on 90H 16 E 0 OUT Button 00H = released, 7FH = pressed OFF N/A
HOT CUE Left Note on 90H 17 F 0 OUT Button 00H = released, 7FH = pressed OFF N/A
HOT START 1 Left Note on 90H 18 F# 0 OUT Button 00H = released, 7FH = pressed OFF N/A
HOT START 2 Left Note on 90H 19 G 0 OUT Button 00H = released, 7FH = pressed OFF N/A
HOT START 3 Left Note on 90H 20 G# 0 OUT Button 00H = released, 7FH = pressed OFF N/A
HOT START 4 Left Note on 90H 21 A 0 OUT Button 00H = released, 7FH = pressed ON N/A
SYNC Left Note on 90H 22 A# 0 OUT Button 00H = released, 7FH = pressed ON N/A
HOT START 5 Left Note on 90H 23 B 0 OUT Button 00H = released, 7FH = pressed ON N/A
HOT START 6 Left Note on 90H 24 C 1 OUT Button 00H = released, 7FH = pressed ON N/A
LOOP 1 IN Left Note on 90H 31 G 1 OUT Button 00H = released, 7FH = pressed OFF N/A
LOOP 1 OUT Left Note on 90H 32 G# 1 OUT Button 00H = released, 7FH = pressed OFF N/A
LOOP 1 RELOOP Left Note on 90H 33 A 1 OUT Button 00H = released, 7FH = pressed OFF N/A
LOOP 1 TRACK Left Note on 90H 34 A# 1 OUT Button 00H = released, 7FH = pressed OFF N/A
LOOP 2 IN Left Note on 90H 35 B 1 OUT Button 00H = released, 7FH = pressed ON N/A
LOOP 2 OUT Left Note on 90H 36 C 2 OUT Button 00H = released, 7FH = pressed ON N/A
LOOP 2 RELOOP Left Note on 90H 37 C# 2 OUT Button 00H = released, 7FH = pressed ON N/A
LOOP 2 TRACK Left Note on 90H 38 D 2 OUT Button 00H = released, 7FH = pressed ON N/A
VINYL Left Note on 90H 39 D# 2 OUT Button 00H = released, 7FH = pressed OFF N/A
SEARCH << Left Note on 90H 40 E 2 OUT Button 00H = released, 7FH = pressed OFF N/A
SEARCH >> Left Note on 90H 41 F 2 OUT Button 00H = released, 7FH = pressed OFF N/A
CUE MIDILOG 1 Note on 90H 42 F# 2 OUT Button 00H = released, 7FH = pressed OFF N/A
CUE MIDILOG 2 Note on 90H 43 G 2 OUT Button 00H = released, 7FH = pressed OFF N/A
CUE Right Note on 90H 46 A# 2 OUT Button 00H = released, 7FH = pressed N/A OFF
PLAY > Right Note on 90H 47 B 2 OUT Button 00H = released, 7FH = pressed N/A OFF
PAUSE || Right Note on 90H 48 C 3 OUT Button 00H = released, 7FH = pressed N/A OFF
PITCH BEND - Right Note on 90H 49 C# 3 OUT Button 00H = released, 7FH = pressed N/A OFF
PITCH BEND + Right Note on 90H 50 D 3 OUT Button 00H = released, 7FH = pressed N/A OFF
HOT CUE Right Note on 90H 51 D# 3 OUT Button 00H = released, 7FH = pressed N/A OFF
HOT START 1 Right Note on 90H 52 E 3 OUT Button 00H = released, 7FH = pressed N/A OFF
HOT START 2 Right Note on 90H 53 F 3 OUT Button 00H = released, 7FH = pressed N/A OFF
HOT START 3 Right Note on 90H 54 F# 3 OUT Button 00H = released, 7FH = pressed N/A OFF
HOT START 4 Right Note on 90H 55 G 3 OUT Button 00H = released, 7FH = pressed N/A ON
SYNC Right Note on 90H 56 G# 3 OUT Button 00H = released, 7FH = pressed N/A ON
HOT START 5 Right Note on 90H 57 A 3 OUT Button 00H = released, 7FH = pressed N/A ON
HOT START 6 Right Note on 90H 58 A# 3 OUT Button 00H = released, 7FH = pressed N/A ON
LOOP 1 IN Right Note on 90H 65 F 4 OUT Button 00H = released, 7FH = pressed N/A OFF
LOOP 1 OUT Right Note on 90H 66 F# 4 OUT Button 00H = released, 7FH = pressed N/A OFF
LOOP 1 RELOOP Right Note on 90H 67 G 4 OUT Button 00H = released, 7FH = pressed N/A OFF
LOOP 1 TRACK Right Note on 90H 68 G# 4 OUT Button 00H = released, 7FH = pressed N/A OFF
LOOP 2 IN Right Note on 90H 69 A 4 OUT Button 00H = released, 7FH = pressed N/A ON
LOOP 2 OUT Right Note on 90H 70 A# 4 OUT Button 00H = released, 7FH = pressed N/A ON
LOOP 2 RELOOP Right Note on 90H 71 B 4 OUT Button 00H = released, 7FH = pressed N/A ON
LOOP 2 TRACK Right Note on 90H 72 C 5 OUT Button 00H = released, 7FH = pressed N/A ON
VINYL Right Note on 90H 73 C# 5 OUT Button 00H = released, 7FH = pressed N/A OFF
SEARCH << Right Note on 90H 74 D 5 OUT Button 00H = released, 7FH = pressed N/A OFF
SEARCH >> Right Note on 90H 75 D# 5 OUT Button 00H = released, 7FH = pressed N/A OFF
MIC 1 ON/OFF Note on 90H 76 E 5 OUT
Push on/push
off sw
NORMAL / REVERSE XFADE Note on 90H 78 F# 5 OUT Slide switch 00H = NORMAL, 7FH = REVERSE N/A OFF
SCRATCH WHEEL Left touch Note on 90H 79 G 5 OUT touch sensor 00H = no touch, 7FH = touch OFF N/A
SCRATCH WHEEL Right touch Note on 90H 80 G# 5 OUT touch sensor 00H = no touch, 7FH = touch N/A OFF
PITCH center click Left Note on 90H 81 A 5 OUT VR center click 00H = no click, 7FH = click OFF N/A
PITCH center click Right Note on 90H 82 A# 5 OUT VR center click 00H = no click, 7FH = click N/A OFF
USB / ANALOG 1 Note on 90H 89 F 6 OUT Slide switch 00H = USB, 7FH = ANALOG OFF N/A
USB / ANALOG 2 Note on 90H 90 F# 6 OUT Slide switch 00H = USB, 7FH = ANALOG OFF N/A
LOAD Left Note on 90H 101 F 7 OUT Button 00H = no assign, 7FH = assign OFF N/A
LOAD Right Note on 90H 102 F# 7 OUT Button 00H = no assign, 7FH = assign N/A OFF
LEFT navigate Note on 91H 103 F# 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
RIGHT navigate Note on 91H 104 F# 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
UP navigate Note on 91H 105 F# 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
DOWN navigate Note on 91H 106 F# 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
Center encoder select Note on 91H 107 F# 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
CUE Left Note on 91H 12 C 0 OUT Button 00H = released, 7FH = pressed ON N/A
PLAY > Left Note on 91H 13 C# 0 OUT Button 00H = released, 7FH = pressed ON N/A
PAUSE || Left Note on 91H 14 D 0 OUT Button 00H = released, 7FH = pressed ON N/A
PITCH BEND - Left Note on 91H 15 D# 0 OUT Button 00H = released, 7FH = pressed ON N/A
PITCH BEND + Left Note on 91H 16 E 0 OUT Button 00H = released, 7FH = pressed ON N/A
VINYL Left Note on 91H 39 D# 2 OUT Button 00H = released, 7FH = pressed ON N/A
SEARCH << Left Note on 91H 40 E 2 OUT Button 00H = released, 7FH = pressed ON N/A
SEARCH >> Left Note on 91H 41 F 2 OUT Button 00H = released, 7FH = pressed ON N/A
CUE MIDILOG 1 Note on 91H 42 F# 2 OUT Button 00H = released, 7FH = pressed ON N/A
CUE MIDILOG 2 Note on 91H 43 G 2 OUT Button 00H = released, 7FH = pressed ON N/A
CUE Right Note on 91H 46 A# 2 OUT Button 00H = released, 7FH = pressed N/A ON
PLAY > Right Note on 91H 47 B 2 OUT Button 00H = released, 7FH = pressed N/A ON
PAUSE || Right Note on 91H 48 C 3 OUT Button 00H = released, 7FH = pressed N/A ON
PITCH BEND - Right Note on 91H 49 C# 3 OUT Button 00H = released, 7FH = pressed N/A ON
PITCH BEND + Right Note on 91H 50 D 3 OUT Button 00H = released, 7FH = pressed N/A ON
VINYL Right Note on 91H 73 C# 5 OUT Button 00H = released, 7FH = pressed N/A ON
SEARCH << Right Note on 91H 74 D 5 OUT Button 00H = released, 7FH = pressed N/A ON
SEARCH >> Right Note on 91H 75 D# 5 OUT Button 00H = released, 7FH = pressed N/A ON
MIC 1 ON/OFF Note on 91H 76 E 5 OUT
Push on/push
off sw
NORMAL / REVERSE XFADE Note on 91H 78 F# 5 OUT Slide switch 00H = NORMAL, 7FH = REVERSE N/A ON
SCRATCH WHEEL Left touch Note on 91H 79 G 5 OUT touch sensor 00H = no touch, 7FH = touch ON N/A
SCRATCH WHEEL Right touch Note on 91H 80 G# 5 OUT touch sensor 00H = no touch, 7FH = touch N/A ON
PITCH center click Left Note on 91H 81 A 5 OUT VR center click 00H = no click, 7FH = click ON N/A
PITCH center click Right Note on 91H 82 A# 5 OUT VR center click 00H = no click, 7FH = click N/A ON
USB / ANALOG 1 Note on 91H 89 F 6 OUT Slide switch 00H = USB, 7FH = ANALOG ON N/A
USB / ANALOG 2 Note on 91H 90 F# 6 OUT Slide switch 00H = USB, 7FH = ANALOG ON N/A
LOAD Left Note on 91H 101 F 7 OUT touch button 00H = no touch, 7FH = touch ON N/A
LOAD Right Note on 91H 102 F# 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
LEFT navigate Note on 91H 103 G 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
RIGHT navigate Note on 91H 104 G# 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
UP navigate Note on 91H 105 A 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
DOWN navigate Note on 91H 106 A# 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
Center encoder select Note on 91H 107 B 7 OUT touch button 00H = no touch, 7FH = touch N/A ON
MIDILOG 1 GAIN Control change B0H 0 OUT Rotary VR 00H min to 7FH max N/A N/A
MIDILOG 1 TREBLE Control change B0H 1 OUT Rotary VR 00H min to 7FH max N/A N/A
MIDILOG 1 MID Control change B0H 2 OUT Rotary VR 00H min to 7FH max N/A N/A
MIDILOG 1 BASS Control change B0H 3 OUT Rotary VR 00H min to 7FH max N/A N/A
MIDILOG 1 LINE Control change B0H 4 OUT Slide VR 00H min bottom to 7FH max top N/A N/A
MIDILOG 2 GAIN Control change B0H 5 OUT Rotary VR 00H min to 7FH max N/A N/A
MIDILOG 2 TREBLE Control change B0H 6 OUT Rotary VR 00H min to 7FH max N/A N/A
MIDILOG 2 MID Control change B0H 7 OUT Rotary VR 00H min to 7FH max N/A N/A
MIDILOG 2 BASS Control change B0H 8 OUT Rotary VR 00H min to 7FH max N/A N/A
MIDILOG 2 LINE Control change B0H 9 OUT Slide VR 00H min bottom to 7FH max top N/A N/A
MIC 1 GAIN Control change B0H 20 OUT Rotary VR 00H min to 7FH max N/A N/A
MIC 1 TONE Control change B0H 21 OUT Rotary VR 00H min to 7FH max N/A N/A
MASTER Control change B0H 28 OUT Rotary VR 00H min to 7FH max N/A N/A
BOOTH Control change B0H 30 OUT Rotary VR 00H min to 7FH max N/A N/A
CROSSFADER Control change B0H 31 OUT Slide VR 00H min left to 7FH max right N/A N/A
CROSSFADER CURVE Control change B0H 33 OUT Rotary VR 00H min to 7FH max N/A N/A
CUE MIX Control change B0H 34 OUT Rotary VR 00H min (cue) to 7FH max (master) N/A N/A
CUE GAIN Control change B0H 35 OUT Rotary VR 00H min to 7FH max N/A N/A
SCRATCH WHEEL Left Control change B0H48,49 OUT Scratch wheel 00H to 7FH clockwise with wraparound OFF N/A
SCRATCH WHEEL Right Control change B0H50,51 OUT Scratch wheel 00H to 7FH clockwise with wraparound N/A OFF
CENTER ENCODER Control change B0H 52 OUT Scratch wheel 00H to 7FH clockwise with wraparound N/A N/A
PITCH SLIDER Left Pitch Bend E0H N/A OUT Slide VR 00H,00H min top to 7FH,7FH max bottom OFF N/A
PITCH SLIDER Right Pitch Bend E1H N/A OUT Slide VR 00H,00H min top to 7FH,7FH max bottom N/A OFF
MIDILOG 1 GAIN Control change B1H 0 OUT Rotary VR 00H min to 7FH max ON ON
MIDILOG 1 TREBLE Control change B1H 1 OUT Rotary VR 00H min to 7FH max ON ON
MIDILOG 1 MID Control change B1H 2 OUT Rotary VR 00H min to 7FH max ON ON
MIDILOG 1 BASS Control change B1H 3 OUT Rotary VR 00H min to 7FH max ON ON
MIDILOG 1 LINE Control change B1H 4 OUT Slide VR 00H min bottom to 7FH max top ON ON
MIDILOG 2 GAIN Control change B1H 5 OUT Rotary VR 00H min to 7FH max ON ON
MIDILOG 2 TREBLE Control change B1H 6 OUT Rotary VR 00H min to 7FH max ON ON
MIDILOG 2 MID Control change B1H 7 OUT Rotary VR 00H min to 7FH max ON ON
MIDILOG 2 BASS Control change B1H 8 OUT Rotary VR 00H min to 7FH max ON ON
MIDILOG 2 LINE Control change B1H 9 OUT Slide VR 00H min bottom to 7FH max top ON ON
MIC 1 GAIN Control change B1H 20 OUT Rotary VR 00H min to 7FH max ON ON
MIC 1 TONE Control change B1H 21 OUT Rotary VR 00H min to 7FH max ON ON
MASTER Control change B1H 28 OUT Rotary VR 00H min to 7FH max ON ON
BOOTH Control change B1H 30 OUT Rotary VR 00H min to 7FH max ON ON
CROSSFADER Control change B1H 31 OUT Slide VR 00H min left to 7FH max right ON ON
CROSSFADER CURVE Control change B1H 33 OUT Rotary VR 00H min to 7FH max ON ON
CUE MIX Control change B1H 34 OUT Rotary VR 00H min (cue) to 7FH max (master) ON ON
CUE GAIN Control change B1H 35 OUT Rotary VR 00H min to 7FH max ON ON
SCRATCH WHEEL Left Control change B1H48,49 OUT Scratch wheel 00H,00H to 7FH,7FH clockwise with wrap ON N/A
SCRATCH WHEEL Right Control change B1H50,51 OUT Scratch wheel 00H,00H to 7FH,7FH clockwise with wrap N/A ON
CENTER ENCODER Control change B1H 52 OUT Scratch wheel 00H to 7FH clockwise with wraparound ON ON
PITCH SLIDER Left Pitch Bend E4H N/A OUT Slide VR 00H,00H min top to 7FH,7FH max bottom ON N/A
PITCH SLIDER Right Pitch Bend E5H N/A OUT Slide VR 00H,00H min top to 7FH,7FH max bottom N/A ON
CUE Left Note on 90H 12 C 0 IN LED 00H = off, 7FH = on N/A N/A
PLAY > Left Note on 90H 13 C# 0 IN LED 00H = off, 7FH = on N/A N/A
PAUSE || Left Note on 90H 14 D 0 IN LED 00H = off, 7FH = on N/A N/A
PITCH BEND - Left Note on 90H 15 D# 0 IN LED 00H = off, 7FH = on N/A N/A
PITCH BEND + Left Note on 90H 16 E 0 IN LED 00H = off, 7FH = on N/A N/A
HOT CUE Left Note on 90H 17 F 0 IN LED 00H = off, 7FH = on N/A N/A
HOT START 1 Left Note on 90H 18 F# 0 IN LED 00H = off, 7FH = on N/A N/A
HOT START 2 Left Note on 90H 19 G 0 IN LED 00H = off, 7FH = on N/A N/A
HOT START 3 Left Note on 90H 20 G# 0 IN LED 00H = off, 7FH = on N/A N/A
HOT START 4 Left Note on 90H 21 A 0 IN LED 00H = off, 7FH = on N/A N/A
SYNC Left Note on 90H 22 A# 0 IN LED 00H = off, 7FH = on N/A N/A
HOT START 5 Left Note on 90H 23 B 0 IN LED 00H = off, 7FH = on N/A N/A
HOT START 6 Left Note on 90H 24 C 1 IN LED 00H = off, 7FH = on N/A N/A
LOOP 1 IN Left Note on 90H 31 G 1 IN LED 00H = off, 7FH = on N/A N/A
LOOP 1 OUT Left Note on 90H 32 G# 1 IN LED 00H = off, 7FH = on N/A N/A
LOOP 1 RELOOP Left Note on 90H 33 A 1 IN LED 00H = off, 7FH = on N/A N/A
LOOP 1 TRACK Left Note on 90H 34 A# 1 IN LED 00H = off, 7FH = on N/A N/A
LOOP 2 IN Left Note on 90H 35 B 1 IN LED 00H = off, 7FH = on N/A N/A
LOOP 2 OUT Left Note on 90H 36 C 2 IN LED 00H = off, 7FH = on N/A N/A
LOOP 2 RELOOP Left Note on 90H 37 C# 2 IN LED 00H = off, 7FH = on N/A N/A
LOOP 2 TRACK Left Note on 90H 38 D 2 IN LED 00H = off, 7FH = on N/A N/A
VINYL Left Note on 90H 39 D# 2 IN LED 00H = off, 7FH = on N/A N/A
SEARCH << Left Note on 90H 40 E 2 IN LED 00H = off, 7FH = on N/A N/A
SEARCH >> Left Note on 90H 41 F 2 IN LED 00H = off, 7FH = on N/A N/A
CUE MIDILOG 1 Note on 90H 42 F# 2 IN LED 00H = off, 7FH = on N/A N/A
CUE MIDILOG 2 Note on 90H 43 G 2 IN LED 00H = off, 7FH = on N/A N/A
CUE Right Note on 90H 46 A# 2 IN LED 00H = off, 7FH = on N/A N/A
PLAY > Right Note on 90H 47 B 2 IN LED 00H = off, 7FH = on N/A N/A
PAUSE || Right Note on 90H 48 C 3 IN LED 00H = off, 7FH = on N/A N/A
PITCH BEND - Right Note on 90H 49 C# 3 IN LED 00H = off, 7FH = on N/A N/A
PITCH BEND + Right Note on 90H 50 D 3 IN LED 00H = off, 7FH = on N/A N/A
HOT CUE Right Note on 90H 51 D# 3 IN LED 00H = off, 7FH = on N/A N/A
HOT START 1 Right Note on 90H 52 E 3 IN LED 00H = off, 7FH = on N/A N/A
HOT START 2 Right Note on 90H 53 F 3 IN LED 00H = off, 7FH = on N/A N/A
HOT START 3 Right Note on 90H 54 F# 3 IN LED 00H = off, 7FH = on N/A N/A
HOT START 4 Right Note on 90H 55 G 3 IN LED 00H = off, 7FH = on N/A N/A
SYNC Right Note on 90H 56 G# 3 IN LED 00H = off, 7FH = on N/A N/A
HOT START 5 Right Note on 90H 57 A 3 IN LED 00H = off, 7FH = on N/A N/A
HOT START 6 Right Note on 90H 58 A# 3 IN LED 00H = off, 7FH = on N/A N/A
LOOP 1 IN Right Note on 90H 65 F 4 IN LED 00H = off, 7FH = on N/A N/A
LOOP 1 OUT Right Note on 90H 66 F# 4 IN LED 00H = off, 7FH = on N/A N/A
LOOP 1 RELOOP Right Note on 90H 67 G 4 IN LED 00H = off, 7FH = on N/A N/A
LOOP 1 TRACK Right Note on 90H 68 G# 4 IN LED 00H = off, 7FH = on N/A N/A
LOOP 2 IN Right Note on 90H 69 A 4 IN LED 00H = off, 7FH = on N/A N/A
LOOP 2 OUT Right Note on 90H 70 A# 4 IN LED 00H = off, 7FH = on N/A N/A
LOOP 2 RELOOP Right Note on 90H 71 B 4 IN LED 00H = off, 7FH = on N/A N/A
LOOP 2 TRACK Right Note on 90H 72 C 5 IN LED 00H = off, 7FH = on N/A N/A
VINYL Right Note on 90H 73 C# 5 IN LED 00H = off, 7FH = on N/A N/A
SEARCH << Right Note on 90H 74 D 5 IN LED 00H = off, 7FH = on N/A N/A
SEARCH >> Right Note on 90H 75 D# 5 IN LED 00H = off, 7FH = on N/A N/A
MIC 1 ON/OFF Note on 90H 76 E 5 IN LED 00H = off, 7FH = on N/A N/A
LOAD Left Note on 90H 101 F 7 IN LED 00H = off, 7FH = on N/A N/A
LOAD Right Note on 90H 102 F# 7 IN LED 00H = off, 7FH = on N/A N/A
Push on/push
off sw
Push on/push
off sw
geposted Tue 23 Jun 15 @ 5:20 am
Ich war mal so frei und hab das im entsprechenden Topic gepostet,
http://www.virtualdj.com/forums/179720/German_Forum/AMERICAN_AUDIO_STAMMTISCH_(Setup__L_sungen__Fixes__Probleme__etc_).html
damit es bei Bedarf auch wiedergefunden werden kann.
thx @ klangkörper für die Tabelle :-)
geposted Tue 23 Jun 15 @ 7:08 am
