So I just plugged my gig drive into my home computer, and about 15% (a few thousand) tracks are showing as unscanned.
It also seems that moving folders causes this, even after refreshing/restarting VDJ...you move the folder/file path and now VDJ behaves as if it's never seen the file, that it's newly added.
This isn't good enough.
geposted Sat 04 Jul 15 @ 1:34 pm
how are you moving the files / folders e.g using your pc explorer or using VDJ file operations?
From my experience the only way to be sure a file / folder keeps all the VDJ settings - scan data / poi's etc is to use the VDJ file operations tab.
hope that helps a bit !
geposted Sat 04 Jul 15 @ 7:31 pm
Most programs work like this. If you don't move the files within that software, how can you expect it to know where they are?
I know there is a way in 7 to fix the missing files.
http://www.virtualdj.com/wiki/Error%20loading%20song.html
I'm not sure where the option is in 8 right now.
geposted Sun 05 Jul 15 @ 2:20 pm
I moved the folders within the browser of the software, and all file info is lost, and as far as I know there's no option to "check" the database for moved files.
geposted Sun 05 Jul 15 @ 4:54 pm
in that case I'm lost as to why - bit worrying though if its a program fault as I am always moving files and folders to different drives !
geposted Sun 05 Jul 15 @ 6:54 pm
One folder was renamed (within VDJ) and all info in that folder was lost, I tried reverting to its original name but no luck. Another folder was moved from one sub folder to another, but the route folder was the same, same result, all database info vanished.
geposted Sun 05 Jul 15 @ 7:03 pm
