Topic: Yamaha mg10xu
Hey guys I got a denon mc6000 and a yamaha mg10xu mixer how can I configure virtual dj to record the audio coming out from the yamaha mixer (the mixer has usb conection) please reply im using virtual dj 8 and windows 7 thanks
geposted Fri 17 Jul 15 @ 9:58 am
Hi picudo,
I think the easiest way is to come out of either the monitor or the headphone output on the mixer and plug that into your pc using the mic in or combo headphone socket, it's usually a 3,5mm jack. Then in the sound config tell vdj to use that as the record source.
regards
ray
geposted Fri 17 Jul 15 @ 2:39 pm
jthankiPRO InfinityMember since 2011
I would like to connect Yamaha MG10UX mixer using USB. What are the settings I need to use to monitor next track via head phone and to ensure VDJ 8 is playing the current track via mixer.
Thank you for any help
geposted Mon 23 Jul 18 @ 5:45 pm
That mixer only has 2 channel in via usb,
while you could get a functional 2 channel external mixer with this setup, generally a desk mixer is for final stage before the amp stack after the controller/dj mixer, send me a pm and I'll explain what you need to do.
geposted Mon 23 Jul 18 @ 6:08 pm
