Forum: Old versions
Topic: Denon Hc4500 64bit windows Vdj 7.4 asio issue
Hi all
Anyone have a link to a driver that will work on 64bit windows with VDJ 7.4 Pro, tried the 2.22 and 1.01 and both say error not enough channels, would like to use the built in sound card, realise this a problem that many have had but wondered if anyone solved it. The unit works fine on my numark djio on asio with vdj
Thanks
Latest firmware etc all installed on the HC4500 and have gone through everything i can find on here
geposted Thu 23 Jul 15 @ 11:42 am
do you have the config set right. you may find that they are set wrong. make sure that output is on external mixer and sound card is on asio
geposted Sun 26 Jul 15 @ 8:21 am
