Is it possible to have a way to append a playlist to automix while another mix is playing? Right now if a play list is playing and I choose another playlist it removes the first playlist and replaces it with the new one. It would be cool to be able to right click the second playlist and either choose to "append to active playlist" or "replace active playlist".
What does everyone else think?
geposted Fri 24 Jul 15 @ 4:07 pm
Yep I agree being able to add a new playlist onto the end fo the current one would be very useful
geposted Tue 18 Aug 15 @ 11:03 am
Access your 2nd playlist from the folder window, and drag from the song window to the automix window.
geposted Tue 18 Aug 15 @ 11:31 am
There is a setting for Auto load play list. Turn that off. Not sure why anyone would want that on by default, always hated that option.
Seriously, who would choose to lose their current work on a list, the instant they select a new playlist?
geposted Wed 19 Aug 15 @ 2:07 am
@ Tantrix
+1
good idea
mfg
ray
+1
good idea
mfg
ray
geposted Wed 19 Aug 15 @ 2:23 pm
+2 - GOOD idea!
I figured out how to accomplish this months ago, which is the same way that
locodog recently suggested of accessing the 2nd playlist from the folder
window, and dragging the songs to the automix window. Your append idea
would be a little easier.
geposted Mon 24 Aug 15 @ 6:36 pm
