Yesterday I downloaded all the VDJ8 video add-ons and installed them all. Now when I play a video and then try loading another track in the player it only wants to link that video. how do I turn that feature off? I don't know which add-on caused this...
geposted Fri 31 Jul 15 @ 10:45 am
That is most likely skin related. What Skin are you using?
geposted Fri 31 Jul 15 @ 10:50 am
I'm using altern8. It didn't do it before installing the video add-ons
geposted Fri 31 Jul 15 @ 10:53 am
Playing around I just noticed that if I drop the song in the video window on the deck it says link video. When I load next to the window it loads the song. I'd like to have that feature turned off and be able to turn it on when I need it.
geposted Fri 31 Jul 15 @ 10:55 am
It would be up to the skin author to decide that.
geposted Fri 31 Jul 15 @ 11:58 am
And it isn't related to a video addon.
That feature was introduced in one of the last 2 updates.
geposted Fri 31 Jul 15 @ 2:11 pm
I will look at adding an option to disable from within the skin.
geposted Fri 31 Jul 15 @ 4:21 pm
Thank you. Thats why it started just today. I just updated VDJ8 as well. Thanks for the info. And thanks in advance if you can add something to turn it on& off. I love the skin!
geposted Fri 31 Jul 15 @ 7:26 pm
