I use Virtual dj with wego2 controller my problem is that when deck A is playing the track ,
as soon as I load deck B & press play the sync on deck A goes crazy I could not match up the beat ,
I have to stop deck B,
in the mean time I press the shift button and the sync button on deck A cueing deck B and it all works I have to repeat
this action in both decks every time can someone resolve my problem please
geposted Mon 03 Aug 15 @ 6:19 am
hallo bigjohn
I also use a wego(1 and 2), although I'm not an expert I'll help if I can. It sounds like a problem with the masterdeck selection, or maybe smartplay.
what skin are you using?
VDJ 7 or 8?
VDJ 7 or 8?
geposted Mon 03 Aug 15 @ 9:11 am
Check the action assigned to the ONINIT key of the WeGO mapping (in Settings-->Controllers tab)
Delete any masterdeck action and you should be fine.
geposted Mon 03 Aug 15 @ 11:44 am
