Hello, I prefer virtual dj 7 over 8, I don't want to buy 8.
How can I buy 7.4.6? I need it to work with ddj-sb controller.
geposted Mon 03 Aug 15 @ 7:20 am
You can't buy VDJ 7 anymore.
But if you buy Version 8, the support is able to put Version 7 into your user account. You are then able to download it from there.
geposted Mon 03 Aug 15 @ 7:21 am
So I looked and the version of 8 i need for my controller is $99. If i buy that one, can I request a license for 7 or do I need to buy the full $299 pro license (which is unfortunately to expensive for me)
geposted Mon 03 Aug 15 @ 7:36 am
I would wait for confirmation from the active staff here, there are many, unlike a lot of product forums.
Their good guy's.
If you pay buy monthly subscription then only VDJ 8 is available, it might be the same for a controller license.
They might give you a good discount on the full software price based on your ownership of a suitable controller.
The system use to work by entering your VDJ LE license into their upgrade web-page, at which time you would be told the size of your discount.
At times the discount has been up to 50%, and VDJ is free with the top Pioneer controller !
Their good guy's.
geposted Mon 03 Aug 15 @ 7:42 am
I'm pretty sure you need the Pro Infinity version for 299$.
Even with the subscriber version you are not granted access to version 7.
geposted Mon 03 Aug 15 @ 7:56 am
Also, how many pcs can I install the software on?
I switch between laptop and pc, would it allow me to install on both?
geposted Mon 03 Aug 15 @ 7:58 am
I believe two officially, though a member of staff here said 3 was acceptable.
I'd like a backup hid in my car, and one at home stored safely.
geposted Mon 03 Aug 15 @ 8:05 am
The guys above are correct:
* VDJ8 Pro Infinity ($299) includes a license for VDJ7 Pro. It's the only version that does.
* The license permits you to install and use the software on two of your computers. Those two can change though, it's not locked to them forever once you have installed.
geposted Mon 03 Aug 15 @ 8:35 am
EULA wrote :
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install the Software on as many computers as you want, but;
- run the Software on a maximum of two computers at any single time, provided that they are at the same physical location and operated by the same person.
http://www.virtualdj.com/atomixproductions/EULA.html
geposted Mon 03 Aug 15 @ 8:42 am
Excellent info PachN !
geposted Mon 03 Aug 15 @ 11:00 am
thanks all for the help.
geposted Mon 03 Aug 15 @ 12:43 pm
