Topic: Text box too small
AxelFSPRO InfinityMember since 2010
At long mix tracks the numbers cannot be read, because the text box is too small.
It seems to be a problem in the default skin:
geposted Mon 10 Aug 15 @ 8:30 pm
If it is ok with the creator of the skin, I can fix this for you very easily. If they approve it to be resized you can send to me a private message to let me know what skin needs to be fixed.
Jon J.
geposted Mon 10 Aug 15 @ 9:11 pm
Hi Jon,
yes, it would be fine if you could fix that for me, but in general the VDJ8 default skin should be fixed by the VDJ developers.
I use the 2 decks display in 1920 x 1080 resolution.
Regards
Axel
geposted Tue 11 Aug 15 @ 8:08 pm
geposted Tue 11 Aug 15 @ 8:18 pm
I can see the same issue too. (but its only cosmetic)
Ive updated to the latest version of the default skin and loaded a very long track, and as you can see the number is drawn too big..
but its only a cosmetic issue and its easily fixable with a quick edit of the .xml file...
geposted Wed 12 Aug 15 @ 5:52 pm
I wonder if it's possible to make this particular text display area smarter?
E.G. it checks the length of the loaded track, and if it's over X time, it displays using a smaller font size.
geposted Wed 12 Aug 15 @ 5:57 pm
Hi,
it is better with the Skin from DjDad, but there would be enough space to make the text box a little larger...
geposted Thu 13 Aug 15 @ 6:54 pm
It is an easy fix. Just look into the xml file and find the textzone that is related to that area and set the text size down a number down 1 or 2 digits then save it and slip it back into the zip file. I have fixed many textzones that had this problem and it work nicely.
if it is something that may be difficult for you, I can do it in 5 mins. But I need the permission of the skin creator and the actual skin in question.
Here is an example. Just lower the number until it fits.
<textzone panel="decksfull" deck="right">
<size width="62" height="16"/>
<pos x="1226" y="198"/>
<up x="1365" y="582"/>
<size width="90" height="10"/>
<text font="digital-7" size="19" color="orange" weight="bold" align="left" scroll="yes" format="%Pspent"/>
<text2 font="digital-7" size="19" color="blue" weight="bold" align="left" scroll="yes" format="%Pleft"/>
<text3 font="digital-7" size="18" color="#FFFFFF" align="left" scroll="yes" format="%author %title"/>
</textzone>
Jon J.
geposted Fri 14 Aug 15 @ 11:30 am
