Just picked up the unit today. Have barely messed with it, but I must say I love the default mapping so far. So well thought out and user friendly.
With that being said, I noticed one issue. The RGBs for the horizontal buttons are not illuminating. The scripting for RGB_BUT_HOR 1 is currently var '$mk2page' 0 ? constant 'yellow' : off. The light is not on. Same issue with the rest of the buttons. I am on page 0 and using default mapper.
Am I missing something?
geposted Tue 11 Aug 15 @ 5:15 am
if you assign that RGB as ..
constant 'yellow'
or
constant 'red'
does it light up yellow or red in all pages ?
constant 'yellow'
or
constant 'red'
geposted Tue 11 Aug 15 @ 12:13 pm
No lights at all. Tried with several different colors.
geposted Tue 11 Aug 15 @ 7:22 pm
Ok here is something i need you to try (there may be something i need to fix in the definition files).
Download and install MIDIOX from http://www.midiox.com/
Run MIDIOX
From the top menu , choose Options-->MIDI Devices
Select the MK2 in both tabs (MIDI Inputs/Outputs) and press OK.
From the menu choose Actions-->Send-->Sysex file
Close the popup window to select a file.
In the Command window type :
90 68 50
From the menu of the window Command Window-->Send sysex
Do you get any color for the 1st HOR button ?
If not, clear the box and type
B0 68 50
Let me know which one of the 2 works
Run MIDIOX
90 68 50
B0 68 50
geposted Tue 11 Aug 15 @ 8:09 pm
Doing it now.
geposted Tue 11 Aug 15 @ 8:11 pm
B0 68 50 gave me blue on the first HOR button.
Love seeing some of the behind the scenes here...
geposted Tue 11 Aug 15 @ 8:17 pm
+1
we need to work on the basic mapping ....
it's good .... but it's not right yet
geposted Tue 11 Aug 15 @ 8:26 pm
Definition files updated.
Fix available in builds ending at .1049 (or higher)
Launch VirtualDJ, let it run for a minute, close, launch again
Verify the build number from settings window
geposted Tue 11 Aug 15 @ 8:40 pm
Works like a charm!!!
Now to map the other pages for some fun stuff!!!
Thanks so much!!!
Thanks so much!!!
geposted Tue 11 Aug 15 @ 8:47 pm
