Forum: Old versions
Topic: Virtual DJ 8 won't record mixing"
Hello I have vdj8. perviously i had vdj le an i upgrade to 8. when i did every time i record a set of mixing an i go to retrieve the file to listen it comes up as a playlist in my finder, a list of the songs i mixed but not mixed just all together all separate. can any one please assit? Thanks!
geposted Tue 18 Aug 15 @ 1:04 am
AsTheDJPRO InfinityMember since 2008
try saving your music in a folder that you made just for your mixes ONLY so VDJ-8 will send your mixes there.
geposted Thu 20 Aug 15 @ 8:28 pm
FYI, there's no need to quote an entire post if it's immediately above your reply. It's obvious who you're replying to!
geposted Fri 21 Aug 15 @ 5:43 pm
ok thanks im new to this sorry. an this helped me i appreciate your answer!
geposted Fri 04 Sep 15 @ 12:13 am
