Forum: Old versions
Topic: Virtual DJ 8 won't record mixing"
Hello I have vdj8. perviously i had vdj le an i upgrade to 8. when i did every time i record a set of mixing an i go to retrieve the file to listen it comes up as a playlist in my finder, a list of the songs i mixed but not mixed just all together all separate. can any one please assit? Thanks!
geposted Tue 18 Aug 15 @ 1:04 am
try saving your music in a folder that you made just for your mixes ONLY so VDJ-8 will send your mixes there.
FYI, there's no need to quote an entire post if it's immediately above your reply. It's obvious who you're replying to!
ok thanks im new to this sorry. an this helped me i appreciate your answer!
