When I try to adjust the frequency knobs for HI, MID and LOW in the mixer it does not affect the sound of the music playing. The only thing that works to adjust the frequencies are the filter, which doesn't give me as much control as i would have if I could adjust hi, mid and low frequencies independently. I'm currently running the latest update. v8 build 2378.
It doesn't work through my controller, nor with the mouse.. Any possible solutions?
Thanks.
Thanks.
geposted Wed 19 Aug 15 @ 2:10 pm
What mixer?
What controller?
Also, if you're listening via headphones then by default EQ changes are not sent to the headphone output. If you want to hear EQ changes in your headphones, you need to enable it.
geposted Wed 19 Aug 15 @ 4:51 pm
groovindj wrote :
What mixer?
What controller?
What mixer?
What controller?
This mixer.
I'm using a Pioneer DDJ-SB. But thanks, I tried to enable EQ via headphones, and it solved my problem. Thank you for the response!
Have a good day.
geposted Wed 19 Aug 15 @ 8:08 pm
How have you enabled the eq via headphones?
geposted Mon 24 Sep 18 @ 3:34 pm
geposted Mon 24 Sep 18 @ 3:47 pm
