Topic: Renaming Virtual Folders fails
When you try and rename a Virtual Folder (red), by right clicking and choosing 'Rename' from the list, the dialog appears however regardless of what you type in there, the folder name does not change.
geposted Fri 21 Aug 15 @ 3:21 am
working here mate (2412) perhaps the vfolder is external?
I've tried creating the folder locally and on an external hard drive, as well using both Mac and PC.
I've found the key to getting this not work properly...
Create a Virtual Folder (Red), and without putting anything inside it, try and rename it. - You will see it fails.
If you add something inside it, and then try and rename it, it then works as expected.
Working here (2425, Windows)....
Can't reproduce it.
Here's a video of the bug:
http://www.hv1.net/vdj/vdjbug.mov
This was tested on the latest few builds of VDJ (latest beta included) as well as under Windows 8, Windows 10, and OS X (Yosemite).
