Forum: Old versions
Topic: 10minute pop up
Hi
Downloaded virtual Dj 8 works fine with my controller (Numark Mixtrack Pro) and I've paid for it to be registered and the software recognises that in the setting however after 10 minutes I keep getting the upgrade prompt and my controller is disabled. So I have to re open and start again.
Has this happened to anyone else
geposted Mon 24 Aug 15 @ 4:33 am
Are you logging in? Are you using the default audio config?
One of these is usually the cause, if you are logging in and think the audio config is correct and it still isn't playing nice show us a picture of your audio settings tab.
