I added a new Virtual Folder , then put some songs in the folder , and yes I opened the folder and they were all there , but after about 20 mins later I went to the folder and the songs were gone . So I tried it again and same thing they kept disappearing >?
geposted Mon 24 Aug 15 @ 1:39 pm
Renaming Virtual Folders is also a problem in recent builds. I lost the ability to rename on both Mac and PC versions. (The red-colored Virtual folders is what I am using.)
geposted Mon 24 Aug 15 @ 3:37 pm
Here's a video of the rename bug:
http://www.hv1.net/vdj/vdjbug.mov
This was tested on the latest few builds of VDJ (latest beta included) as well as under Windows 8, Windows 10, and OS X (Yosemite).
geposted Tue 25 Aug 15 @ 5:01 pm
Do not hook up your external hd drive and try renaming it now
geposted Thu 27 Aug 15 @ 1:45 pm
NG- When I shot that video, I was using a Macbook Air (which I use for SW development), and no external HDD.
geposted Thu 27 Aug 15 @ 8:42 pm
