Hi guys! I am currently using the Denon mc6000 mk2 with windows 7 64 Bit. I am having some very small audio dropouts. I have the latency at 1ms with a brand new chroma high quality gold plated usb cable. Firmware and drivers and eveything is up to date. Songs are in internal hard drive. Computer and songs are very clean! What can i do to completely remove these audio dropouts!They are really really tiny but they annoy me lol! I've had this problem for a while now! Been using virtual dj 8 4 months now
geposted Sat 29 Aug 15 @ 6:16 pm
adjust the latency higher
geposted Sat 29 Aug 15 @ 6:17 pm
Would like some body's personal experience with the same setup
geposted Sat 29 Aug 15 @ 6:23 pm
Ok so far i plugged the denon on a usb 2.0 port instead of a 3.0 no audio dropouts but...when having vinyl mode and scratching you notice it no matter what the latency is
geposted Sat 29 Aug 15 @ 6:28 pm
you can use this tool to help you judge where you can safely put you latency http://www.resplendence.com/latencymon
geposted Sat 29 Aug 15 @ 7:03 pm
Thanks I'll try it out
geposted Sat 29 Aug 15 @ 7:47 pm
weirdest thing. i changed usb ports and went from a usb 3.0 to a usb 2.0 and seems like i can barely hear anything....
geposted Sun 30 Aug 15 @ 10:53 am
