I was reading this thread https://virtualdj.com/forums/201088/General_Discussion/Automix_Compared_to_VDJ7_and_VDJ8.html?search=jiver&page=1
And was wondering if there was now an easier way to prevent tracks in automix with different BPM from automatically adjusting the pitch when mixing next songs.
Managed to figure out the bpm match for decks in npormal play by setting autobpmmatch to "No". after a bit of searching but can't find this setting for automix
Could it be either automix mode (set default to smart) or autobeatmatchonfade ( set default to yes)
Seems to have no effect so assume not
geposted Wed 09 Sep 15 @ 5:47 pm
Ok not sure if correct way but.
In automix, click the dot and set "automix type" to "fade remove silence" and set automix length to 8 seconds.
geposted Wed 09 Sep 15 @ 5:56 pm
