Every time I click "yes" on the update offer to Build 2441, Virtual DJ bring the message back without update putting the update offer in an endless loop unless I hit "no" on the update. Please let me know what's going on here.
geposted Wed 16 Sep 15 @ 11:06 pm
goto /Documents/VirtualDJ/Cache folder and delete any temporary downloaded file of VirtualDJ. Open VirtualDJ 8 after that and try again.
geposted Wed 16 Sep 15 @ 11:53 pm
I was greeted with the update prompt again. I hit yes. The software restarted and then brought the prompt again. It continues in the endless loop unless I say click no to the prompt.
geposted Thu 17 Sep 15 @ 2:03 am
I have Virtual DJ 8. Every time i disconnect and reconnect it says Your Virtual DJ has just been updated, do you want to use the new version now I click on Yes. It is every day of every hour this message appears. I think the last updates from months back must have got corrupted because i had problems with my Router. Is there a way of forcing an update, or uninstalling an update to correct this? Can it be done manually?
geposted Wed 25 Oct 17 @ 4:33 pm
Yes. Go here http://www.virtualdj.com/download/build.html
geposted Wed 25 Oct 17 @ 6:08 pm
Just to say thank you to Groovindj it worked well. I get a lot of adverts in the right pane of virtual DJ. I have ran the likes of antivirus and crap cleaner and malware. Is it normal for adverts to come through, and can they be removed somehow?
geposted Tue 31 Oct 17 @ 5:35 pm
geposted Sat 04 Nov 17 @ 12:04 am
Yes it is normal for the free home version of VDJ to display adverts. They can be removed simply by purchasing a VDJ license.
geposted Sat 04 Nov 17 @ 12:11 am
