Topic: vdj7 samples on vdj8
how can ı use vdj7 samples on vdj8? a lot of vdj7 samples not wrking on vdj8..
geposted Sun 20 Sep 15 @ 3:09 pm
Please give more information.
What format are the samples?
Did you move them or just navigate to the vdj7 sample banks?
Do they just not play or do they not load or do you get an error?
Regards,
Daniel
geposted Tue 22 Sep 15 @ 1:19 pm
stonbriPRO InfinityMember since 2010
I have the same issue, the ones I had in version 7 worked with no issues but I try to use the same ones in version 8 they don't. Why in the world would that need to change, smh
geposted Mon 12 Oct 15 @ 4:46 pm
