Topic: Cue Points?
Hi all,
I've been hunting around and couldn't find what I needed to answer this question...
Is there a global option to make Cue1 the default load point?
There was an old thread that touched on this but it was kinda old and thought they may have changed it, because I can't seem to find it going by the exact wordage they used.
Thanks..
geposted Thu 24 Sep 15 @ 6:50 pm
turn on advanced options and search for "autoCue" in the audio section set it to "cue"
you will be good to go
