Topic: Crash Report.................. - Page: 3
With videoMemory on Automatic the memory usage stays normal for me even when using this vdjedit.
When putting it to 1980 as you had it, I can indeed see it rising a lot in build 2465, but with the fix I made for the source length of 0 it doesn't seem to rise as much anymore.
So I think the memory usage should remain good for you too when it's put to automatic?
Just had a crash on my PC using the newest build after about an hour and a half.
I just finished up recording a video set using Bandicam.
I had stopped recording and loaded the video which is in AVI format, anyways the track was loaded and I started to play it. I used my mouse to shut off TellyVisuals and VDJ crashed.
2 seconds later it opened back up and continued to play the recorded track.
Sooooo what was the cause of this last crash please??
