Forum: Old versions
Topic: Error in VirtualDJ Remote 8
Hello. After ios upgrade to version 9.0 for iPad 2, my VirtualDJ Remote 8 in the FOLDER looks like the image. Trying to reinstall not repaired the fault. Does anyone have a similar problem?
geposted Sun 27 Sep 15 @ 9:06 pm
It also appears to be an issue with iOS 9 on the iPhone 6.
I would recommend rolling back to iOS 8 for now until a fix can be found and released.
geposted Tue 29 Sep 15 @ 9:04 pm
Good job!!! The problem removed. The new version of Virtual DJ Remote 8.0.2502
Thank you
geposted Sat 24 Oct 15 @ 2:59 pm
Another question. There is a new version of ios 9.1, or the update will resolve with iRemote not return?
geposted Sat 24 Oct 15 @ 3:24 pm
Please do not post the same message in two forum areas at once.
geposted Sat 24 Oct 15 @ 3:39 pm
