Hi,
If I create in a playlist called "REquests" then rename it to "Requests" the second "E" does not change to lowercase.
This is in a playlist subfolder if it makes a difference.
geposted Fri 02 Oct 15 @ 2:44 am
Does it change if you collapse and expand the subfolders after renaming the file?
geposted Fri 02 Oct 15 @ 11:57 am
No.
geposted Fri 02 Oct 15 @ 12:18 pm
Windows file system does the same thing with file naming. Your file path has to change because the computer does not care about the difference between caps and lower case. It can be fixed in two steps
1. Delete or add an character "Rquests" (in this case the "E")
2. Then fix the E "Requests"
geposted Fri 02 Oct 15 @ 2:47 pm
