Topic: Automix Shuffle
Hi,
With Automix engaged and using shuffle (not shuffle once), sometimes the second track does not show in the waveform and then stops after the current playing track is over.
geposted Sun 04 Oct 15 @ 8:14 pm
It have happened to me too. Next song loaded as black as all the files were played and there is no more songs in the playlist and there was a lot. Tested with latest version.
Best Regards.
geposted Mon 05 Oct 15 @ 2:01 am
DJ_SVOPRO InfinityMember since 2006
Happened to me for the first time today. Latest Beta build, DELL XPS 8700/i7 Quad Core/32 GB Ram/4TB External.
geposted Mon 19 Oct 15 @ 3:03 am
If you want automix to continue playing after all songs have played you need to turn on Repeat from the automix menu.
geposted Mon 19 Oct 15 @ 5:16 am
Hi. This is before all songs have finished playing. While in the list it does this.
geposted Mon 19 Oct 15 @ 9:17 am
And you didn't manually switch to any song or skip a song during automix?
geposted Mon 19 Oct 15 @ 9:31 am
Yes, that's correct.
geposted Mon 19 Oct 15 @ 10:18 am
No switches or changes.
geposted Mon 19 Oct 15 @ 8:28 pm
