Hi,
How do you change the video device driver in VDJ 8, in 7 it was easy, cannot find it in 8.
Help please
T
Help please
T
geposted Thu 08 Oct 15 @ 9:38 pm
That's a good question, and I'm not sure if I have the correct answer, but I think you change it on your machine and VDJ will select the one it sees. What are the choices on your machine, and which one does VDJ detect?
geposted Fri 09 Oct 15 @ 1:57 am
I have Intel Graphics 3000 and Nvidia GeForce GT 540m.
The display settings from the control panel show the Intel., not sure how to change, any help would be useful, don't want to start altering things withour being sure it's correct
T
geposted Fri 09 Oct 15 @ 10:54 am
Simply use the NVIDIA Control Panel, add virtualdj.exe to the list of programs and select the NVIDIA for it.
geposted Fri 09 Oct 15 @ 11:14 am
Thanks for your replies, yes I did manage to crack it,
geposted Fri 09 Oct 15 @ 6:22 pm
