Topic: VDJ PRO 8 Problems
Recently i have been having trouble on opening virtual dj pro 8 mac version when i would open it the icon will appear along with the top bar but the program it self doesn't appear so i un installed it and installed it again this time it opened so when i went to close it and bring it back up it did the same thing has anyone ever come across this issue before running a mac here is my specs on my mac serial number has been removed for privacy.
geposted Wed 21 Oct 15 @ 8:43 pm
Remove VirtualDJ from your apps folder.
Go to Documents\VirtualDJ\Cache and remove any update files from there.
Download and install the current public VirtualDJ build: http://www.virtualdj.com/download/index.html
If at that point it is still crashing, go to Documents\VirtualDJ and rename settings.xml to something else and retry.
geposted Thu 22 Oct 15 @ 8:32 am
I have the same problem as Slickrick1386. I followed the instructions given to him and it seemed to work so far. I have a question though... Should we not do any updates from now on? What should I do?
I appreciate any help
geposted Sat 24 Oct 15 @ 1:10 am
It was a regression bug on the Mac in one of the recent beta builds that was fixed in 2522.
geposted Sat 24 Oct 15 @ 9:14 am
