hi guys... i try to retag some video file .mkv but it works only random
on vdj i can see the correct tag but when i go on windows folder.. i can't see the correction only on some few files..
i use latest public version.. and windows 10 correctly update on today 24/10/15...
any suggestion?? please solve.
geposted Sat 24 Oct 15 @ 3:57 pm
windows 7 can not view mkv tags after testing i see windows 10 can nice.
VDJ doesn't appear to be able to tag MKV files (or there is a bug) it only is writing to the database so what ever your adding in vdj will not go with the file.
more info on mvk tags if needed -> http://www.matroska.org/technical/specs/tagging/example-video.html
geposted Sat 24 Oct 15 @ 5:04 pm
hi wicked thanks for your answer..
as today i can happy confirm that the leatest update od vdj and windows go better but THE PROBLEM IS NOT SOLVE AT ALL..
if i retag some video .Mkv ... i can see correct tag on vdj, and correct name files on windows 10 folder.. but if i see the windows 10 tag (example: author or title) nothing happen.. as before...
probably is a bug ... what do you think?? and where can i suggest this problem to developer??
geposted Sat 02 Jan 16 @ 2:27 am
VDJ currently does not support writing mkv tags, so indeed changes are only stored in the vdj database and thus only visible within vdj.
geposted Sat 02 Jan 16 @ 9:06 am
