Can you download a skin & then edit that skin with the Developer SDK or do you have to start from scratch?
Are there any skins that contain a user field? (When you edit a tag of a song, the User Fields Field1 and Field2 are present. You can add something in these fields and then add that field into your list of songs and sort by it)
geposted Wed 11 Nov 15 @ 9:15 pm
The XML can be modified easily enough to change the text.
geposted Wed 11 Nov 15 @ 9:26 pm
Thanks! I'll have a go.
geposted Wed 11 Nov 15 @ 9:49 pm
Well, that was nice and easy! Inserted the below into the Time/Year/Gain / Key Textzone section for each deck and bingo! Thanks again!
<textzone deck="1">
<pos x="250" y="130"/>
<size width="72" height="22"/>
<text font="ARIAL" size="18" color="red" weight="bold" align="right" format=" `get loaded_song 'Field1'`"/>
</textzone>
geposted Wed 11 Nov 15 @ 10:14 pm
Glad you are sorted!
geposted Wed 11 Nov 15 @ 10:54 pm
