Hi has v8 had any updates so you can text happy birthday or something on screen like you can on v7. Thanks Phil
geposted Wed 18 Nov 15 @ 11:28 pm
Hi,
Since VirtualDJ 8 we have the TEXT plugin in both Windows and MAC versions. It is on EFFECTS --- VISUALIZATIONS --- TEXT. Click on the gear aside the effect on the list or press "+" or GUI to get the text box open.
You need to apply your text or options to the text box and also ACTIVATE the effect to display it on the screen.
VirtualDJ 8.1 has this as well.
geposted Thu 19 Nov 15 @ 1:12 am
How do I text on screen on vj8 ? Do I need a plugin ? Thanks
geposted Thu 19 Nov 15 @ 3:45 am
Hi I can't find the text plugin ? For v8 what is it called ? And where do I find it. Cheers Phil
geposted Thu 19 Nov 15 @ 3:49 am
Manual Page 26
Section : Video effects
geposted Thu 19 Nov 15 @ 4:53 am
geposted Thu 19 Nov 15 @ 5:01 am
