Forum: VirtualDJ 8.1 Technical Support
Topic: Fan
AsTheDJPRO InfinityMember since 2008
The fan is running more then normal with VDJ-8.1/DDJ-SX-2 open..also? or is that OK ?
OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
geposted Thu 19 Nov 15 @ 12:36 am
I'm just testing VDJ8.1 with OSX 10.11.1 El Capitan, 2.6Ghz, 4Gb RAM with an MC6000 Mk1.
Temp is 59C and fans running at 4250rpm. I use http://www.Crystalidea.com Mac Fans Control set to 53C-63C
Its pretty much the same as in previous versions.
geposted Thu 19 Nov 15 @ 1:28 am
